1989 Pontiac Bonneville LE, Engine/Propulsion Demonstration
1989 Pontiac Bonneville 3.8L V6 - Yellow is secondary ignition at cylinder #4 ignition cable, green is a Firstlook Sensor in the brake booster hose, blue is the crankshaft position sensor signal, and red is an amp clamp around battery negative. This capture i...
1989 Pontiac Bonneville LE 3.8L
