1989 Pontiac Bonneville LE, Engine/Propulsion Demonstration
1989 Pontiac Bonneville 3.8L V6 - Yellow is secondary ignition at cylinder #4 ignition cable, green is a Firstlook Sensor in the dipstick tube, blue is a pressure transducer in cylinder #1, and red is an amp clamp around the negative battery cable. This captu...
1989 Pontiac Bonneville LE 3.8L
