1989 Pontiac Bonneville LE, Engine/Propulsion Waveform
1989 Pontiac Bonneville 3.8L V6 -- Fuel injectors disconnected, cranking. Yellow is secondary ignition on cylinder #4 ignition cable, green is a Firstlook Sensor in the dipstick tube, blue is the crankshaft positon sensor, and red is engine relative cranking ...
1989 Pontiac Bonneville LE 3.8L
