1998 Ford Expedition XLT, Ignition Waveform
1998 Ford Expedition 5.4L - Yellow is coil #5 primary drive and green is coil #5 current ramp. Capture is at idle. Engine had intermittent misfire, especially under load. Coolant was found in spark plug tube. Even after liquid was removed misfire still per...
1998 Ford Expedition XLT 5.4L
