1998 Ford Expedition XLT, Engine/Propulsion Waveform
1998 Ford Expedition 5.4L - Running compression waveform of cylinder #5 with ignition coil firing through spark tester. Engine has no known mechanical issues and has 220k on the odometer. Transducer is a 30"hg to 300psi transducer using the following transla...
1998 Ford Expedition XLT 5.4L
