2004 Volkswagen Passat GLS, ECM/Inputs/Outputs Waveform
2004 VW Passat 1.8L FWD - Yellow is CKP, green is CMP, blue is coil #1 drive, and red is injector #1 drive. Engine is cranking in this picture as vehicle was a no start due to a failed fuel pump. One the fuel pump was replaced the vehicle had no obvious runn...
2004 Volkswagen Passat GLS 1.8L
