1998 Toyota 4Runner Limited, Ignition Waveform
1998 Toyota 4Runner 3.4L - Steady misfire in this capture. Yellow is common coil power feed current ramp, green is coil #1 primary (cylinders 1/4), blue is coil #2 primary (cylinders 3/6), and red is coil #3 primary (cylinders 2/5). Firing order is 123456, w...
| Engine | 3.4 L / 6 cyl / GAS |
1998 Toyota 4Runner Limited 3.4L
