Relative Compression Waveform
Posted to the Waveform Library on 2/4/2012
Relative compression waveform using snappy's low amp probe using the 20 amp scale and viewing it on the scope in the Graphing Multimeter. With scope scale set on 2 volts with a 2 second sweep. This can be done with this one when you don't have a 400 or 600 amp...
