1998 Audi A6 Quattro, Engine/Propulsion Waveform
1998 Audi A6 2.8 AHA 155,000 miles -- Subtle misfire at idle in cylinder #5. Misfire counters slowly incrementing but no code set. Waveform is a running compression waveform on cylinder 5 taken at idle with a Snap On 500psi pressure transducer.
| Engine | 2.8 L / 6 cyl / GAS |
| Condition | Unknown |
1998 Audi A6 Quattro 2.8L
