2007 Toyota Camry LE, Ignition Waveform
The waveform shows Ch A as the IGf(confirmation) signal to the PCM from all six ignition coils in one single wire. Ch B is #2, Ch C is #4, and Ch D is # 6 ignition IGt's trigger signals from the PCM. The waveform on Ch A is missing the IGf from ignition coil ...
| Engine | 3.5 L / 6 cyl / GAS |
2007 Toyota Camry LE 3.5L
