2001 Ford F-150 XL, ECM/Inputs/Outputs Scan Data
Vehicle had lean codes after repairing a #2 misfire. Found aftermarket air intake system causing incorrect airflow readings. This was taken at WOT during test drive after installing the OEM air intake system.
| VIN | 1FTRW07L21 |
2001 Ford F-150 XL 5.4L
| VIN | 1FTRW07L21 |
