2002 Chrysler Sebring LXi, ECM/Inputs/Outputs Waveform
Here is a scope pattern of the cam and crank sync,the above pattern is when it was running rough (before) The below pattern is the (after) pattern when the cam trigger was straightened. <-Now its running perfect with no codes.
| Engine | 2.7 L / 6 cyl / GAS |
2002 Chrysler Sebring LXi 2.7L
