2002 Jaguar XK8, Engine/Propulsion Waveform
Here is an example of how to mark exhaust cam timing. The second cursor shows BDC at the end of the decompression stroke and the beginning of the exhaust stroke. This cam is some 40 degrees retarded because of slippage between the cam gear and the camshaft.
| Engine | 4.0 L / 8 cyl / GAS |
2002 Jaguar XK8 4.0L
