2003 Nissan Altima, ECM/Inputs/Outputs Waveform
Timing on scanner was showing -26 degrees You can see the cam crank sync is not where it should be, Timing chain removal time.
| Engine | 2.5 L / 4 cyl / GAS |
2003 Nissan Altima 2.5L
