2002 Dodge Grand Caravan EL, Emissions Waveform
Posted to the Waveform Library on 10/30/2010
Zoomed out compete Evap Monitor Test; green is LDP solenoid control (zero volts is energized) and yellow is LDP switch (zero volts is diaphragm held up under pressure). The test starts by raising engine RPM, then it doesn't do anything else until 1-2 minutes ...
2002 Dodge Grand Caravan EL 3.3L
Engine3.3 L / 6 cyl / FLEX
SubsystemEmissions
SubsystemEmissions
