2007 Toyota Camry SE, Ignition Waveform
Posted to the Waveform Library on 6/25/2010
Channel A waveform in blue is IGT voltage from the ECM to the igniter. Channel B waveform in red is the coil primary current. This shows that when IGT is high, current is flowing in the coil primary. When IGT goes low, coil primary is switched off, establis...
2007 Toyota Camry SE 3.5L
Engine3.5 L / 6 cyl / GAS
Trans6-speed AutomaticTransaxle (Electronic)
SubsystemIgnition
ConditionKnown Good
SubsystemIgnition
ConditionKnown Good
