2002 Ford Explorer XLS, ECM/Inputs/Outputs Waveform
Correct Cam-Crank sensor correlation (running at idle) for Ford SOHC 4.0L engine. This engine uses a crank to balance shaft chain, crank to jackshaft chain and two jackshaft to cam chains (one at front of left bank head and one at rear of right bank head) whic...
| Engine | 4.0 L / 6 cyl / GAS |
2002 Ford Explorer XLS 4.0L
