2002 Mitsubishi Eclipse GT, ECM/Inputs/Outputs waveform
Posted to the Waveform Library on 8/25/2009
egr control solenoid, showing voltage applied and current draw. note solenoid is partially shorted and drawing current when not turned on by control signal. had set code p0403
2002 Mitsubishi Eclipse GT 3.0L
Engine3.0 L / 6 cyl / GAS
