2003 Ford F-350 Super Duty XL, Engine/Propulsion
Channel #1 (yellow) is the MAF sensor. The down spike is the pressure change in the intake during the misfire "pop". Channel #2 (green) is cylinder #4 compression pressure only. The injector is disabled. Note the cylinder #4 compression drops to 50 psi during ...
| VIN | 1FDSF34P73 |
| Engine | 6.0 L / 8 cyl / DIESEL |
2003 Ford F-350 Super Duty XL 6.0L
| VIN | 1FDSF34P73 |
