2000 Toyota Corolla, Engine/Propulsion waveform
Posted to the Waveform Library on 8/18/2008
WOT snap with a pressure transducer in the oil stick tube. stuck piston rings , using more than 1 quart per 1000 miles. also has p0420 intake vacuum is 21" steady smooth at hot idle
2000 Toyota Corolla VE 1.8L
Engine1.8 L / 4 cyl / GAS
Trans5-speed StandardTransaxle
SubsystemEngine/Propulsion
