2003 Subaru Outback, ECM/Inputs/Outputs waveform
4 cyl DIS Ignition coil primary current signatures in parade , the signature must be the same , they are not . Bad ignition wire and possible failing coil
| Engine | 2.5 L / 4 cyl / GAS |
2003 Subaru Outback Limited 2.5L
