1999 Ford E-150 Econoline, ECM/Inputs/Outputs waveform
using AMD one option is to connect to the o2 sensor of the suspected bank , you can look at the o2 sensor waveform with a good graphing scan tool to see which bank is the bank you should be looking at ,
| Engine | 4.2 L / 6 cyl / GAS |
1999 Ford E-150 Econoline 4.2L
