2001 Lincoln LS, ECM/Inputs/Outputs waveform
Here is a waveform showing the relationship of crank sensor to cam sensor. this eng. is in time and running fine with no dtc. It had been setting PO340 due to a timing chain tentioner broken shoe.
| Engine | 3.9 L / 8 cyl / GAS |
2001 Lincoln LS 3.9L
