1998 Ford E-250 Econoline, Ignition waveform
1998 Ford Econoline E250 5.4L - This vehicle came in with a complaint of intermittent miss just coming off idle. P0305 was set. These captures are of the the #5 ignition coil during light power braking in the stall. The top capture is with the original coil...
TECH: Misfire at 40 to 45 mph under light throttle
TECH: Is this a bad pcm ignition driver?
TECH: Compare Coil Ramping
TECH: Accel supercoils in 5.4 Ford
TECH: Misfires under load. P0300, P0171
TECH: 2010 Ford Fusion P0151, and misfire
THEORY: Expedition with heavy misfires
THEORY: FORD C.O.P QUESTION
THEORY: Primary/secondary Ignition help
1998 Ford E-250 Econoline 5.4L
