2001 Volkswagen Passat, ECM/Inputs/Outputs waveform
Posted to the Waveform Library on 2/15/2008
This capture is with the flywheel at tdc, cam at mark on valve cover and the sprocket on the exh. cam reindexed to the correct position.
2001 Volkswagen Passat GLS 1.8L
Engine1.8 L / 4 cyl / GAS
Trans5-speed StandardTransaxle
Component,
ConditionKnown Good
Component,
ConditionKnown Good
