1996 Toyota Camry, BATT/Charging/Starting Waveform
1996 Toyota Camry LE 2.2L w/ AT - Vehicle had extended cranking times with erratic and labored cranking speeds. Strong burnt electrical smell from under hood. Yellow trace in both captures is starter current draw taken with a high amperage clamp. Green trace i...
1996 Toyota Camry DX 2.2L
