2003 Subaru Outback, Vacuum/Pressure/Flow Waveform
Posted to the Waveform Library on 1/20/2008
pico 6 , running compression on cylinder one with pressure transducer in the filler neck of the radiator , pressure pulses sync with the running compression waveform , bad , leaking path from combustion to coolant.
2003 Subaru Outback Limited 2.5L
Engine2.5 L / 4 cyl / GAS
SubsystemEngine/Propulsion
