1995 Subaru Legacy, Vacuum/Pressure/Flow Waveform
awi waveforms separated from the original Pico 6 capture , then
overlayed , cursors are added to show exhaust backpressure and
exhaust valve opening and closing events
TECH: HELP Please exhaust back pressure specs
TECH: skipping Isuzu
TECH: Running Compression Test -- Strange
TECH: rough idle; detonation after valve job
THEORY: Cranking Compression and new technology
THEORY: MAF reverse flow recognition
TECHTIP: Exhaust back pressure , running compression
1995 Subaru Legacy L 2.2L
