1995 Subaru Legacy, HO2S, Ignition - Secondary, O2S, Vacuum/Pressure/Flow Waveform
Posted to the Waveform Library on 11/16/2007
using annowave i have matched cursors to = 720 degrees of waveform , scan data shows 20 degrees of advance , so set low value of the cursors to -20 degrees and the align that with a spark event , go forward to Exhaust Valve Open event and drop a cursor ... 170...
1995 Subaru Legacy L 2.2L
Engine2.2 L / 4 cyl / GAS
Component, , ,
Component, , ,
