1993 Nissan 240SX, Ignition - Secondary, MAF, Vacuum/Pressure/Flow Waveform
using a pressure transducer in the exhaust , and measuring the MAF sensor output with scope set on AC coupling , the misfire in Cyl 3 is relected in the waveform of the MAF sensor for Cylinder 2
| Engine | 2.4 L / 4 cyl / GAS |
| Component | , , |
1993 Nissan 240SX 2.4L
| Component | , , |
