Alternator waveform simulation
Posted to the Waveform Library on 4/15/2007
Simulated comparison between 6 diode WYE and 8 diode WYE with a rectified neutral connection. Voltage waveform across a resistive load only. All windings spec'd 12v/60Hz at 0/60/180 degrees respectively.
