1995 Chevrolet C1500, Transmission Photo
Tube with internal 'O' ring on output shaft isolates slip yoke splines from ATF in 2wd applications. This design may or may not be used in specific applications and requires the use of the appropriate design propeller shaft slip yoke with a vented plug when th...
| Subsystem | Transmission |
1995 Chevrolet C1500 5.7L
