2001 Volkswagen Cabrio, Ignition - Ground, Ignition - Primary, Ignition - Secondary Waveform
ABA 2.0 liter engine New Beru Ignition coil module assembly - ignition coil primary current with the signal from the ECM to the ignition coil module and good secondary voltage - at hot idle. also shown are new good coil turn on oscillations.
| Component | , , |
2001 Volkswagen Cabrio GL 2.0L
| Component | , , |
