2001 Volkswagen Cabrio, GND, Ignition - Ground, Ignition - Primary, Ignition - Secondary, Vacuum/Pressure/Flow Waveform
Posted to the Waveform Library on 3/23/2007
2001 cabrio ABA 2.0 engine , cranking no start , BAD IGNITION COIL - primary current rises almost vertically and there are zero coil oscillations at the start of the current waveform . but the coil module is good and the signal from the ECM to control the coil...
2001 Volkswagen Cabrio GL 2.0L
Engine2.0 L / 4 cyl / GAS
SubsystemIgnition
Component, , , ,
SubsystemIgnition
Component, , , ,
