1998 BMW 528i, GEN (Alternator) Waveform
alternator ripple with alternator current hot idle , heater blower and high beams maxed, in gear brake on. alternator ripple is right at the 500mv max limit .and 80 amps is not peak output for the alternator so ripple will increase when peak output is reached ...
| Engine | 2.8 L / 6 cyl / GAS |
1998 BMW 528i 2.8L
