1998 BMW 528i, FP Waveform
Posted to the Waveform Library on 3/16/2007
Fuel pump current with AC coupling , the fuel pump is failing and cavitating , had misfire on cyl 1 , cyl is higher than the other cylinders and the last one on the rail away from the pressure hose connections to the rail .
1998 BMW 528i 2.8L
Engine2.8 L / 6 cyl / GAS
Trans4-speed AutomaticTransmission (Electronic)
SubsystemFuel Supply
1998 BMW 528i 2.8L
