2002 Pontiac Grand Am, CKP Sensor, CMP Sensor Waveform
This is a Known good signal for only running on Cyl 2-3. Cylinders 1-4 were misfiring at this time. You can see the Cam signal which is supplied by the ICM has a longer time base then if the system was running on all 4 cylinders. The coil Control for 1-4 was n...
2002 Pontiac Grand Am SE 2.2L
