2002 Pontiac Grand Am, CKP Sensor, CMP Sensor Waveform
The Cam sensor signal is supplied by the ICM to the PCM, This is a known good signal @idle. Crank Sensor signal tested at PCM connector.
2002 Pontiac Grand Am SE 2.2L
