1998 Honda Civic, HO2S, Ignition - Secondary, Vacuum/Pressure/Flow Waveform
Posted to the Waveform Library on 12/3/2006
Misfire every 4th cylinder , 4 cylinder engine . FLS C measureing pressure in the Coolant , o2 sensor is capturing lean puff 1x per 4 ignition events , weak pressure pulse lines up with lean puff , 50% of the time .
not a vacuum leak , compression 'good'. PD...
1998 Honda Civic EX 1.6L
Engine1.6 L / 4 cyl / GAS
Trans5-speed StandardTransaxle
SubsystemEngine/Propulsion
Component, ,
Component, ,
