1998 Volkswagen Passat, ECM/Inputs/Outputs Waveform
1998 AEB 1.8 t passat , bad coil driver in the module above the air filter - P0302 - common failure - compare to the Pico diagnostics data waveform
1998 Volkswagen Passat GLS 1.8L
