1998 Acura Integra, Ignition - Secondary, Injector, Vacuum/Pressure/Flow Waveform
bad exhaust valve on #2 displayed by erratic intermittently low fireing KV on #2 and #4 [not as bad] , also on the far right you can see lean misfire on Cyl 4 because of cavitating fuel pump filling the rail with some vapor or air other than fuel . the exhaust...
| Component | , , |
1998 Acura Integra GS-R 1.8L
| Component | , , |
