1994 Ford E-250 Econoline, VSS Waveform
The Programmable Speedometer Odometer Module (PSOM) is defective. THIS IS THE SIGNAL FROM PSOM TO PCM. SHOULD BE A 5 VOLT SQUARE WAVE. Notice: THIS SIGNAL IS GOING BELOW ZERO!! Causing speedometer to be intermittent/ inaccurate.
| Engine | 5.8 L / 8 cyl / GAS |
1994 Ford E-250 Econoline 5.8L
