GM Starter solenoid Amp draw, top view : solenoid does not close contacts, bottom view : normal operation.
Posted to the Waveform Library on 5/21/2006
Complaint: occasionally NO starter operation.
Top view Hook-up is: AMP PROBE around ( purple )the starter switch wire, and the volt meter leads are from BATT NEG terminal to the S terminal at the solenoid.
Top view, Amp-draw ( blue trace )is at 56 Amps wit...
