2005 Ford F-250 Super Duty Lariat, ABS Wheel Speed Sensors Waveform
Rear Wheel speed sensor in a 2005 F-150 located at the top of the Differential housing. Scoped out as a flat line. Was indicateing code C1230 Using Genisys scanner with 2005 domestic and 2004 ABS/SIR software.
2005 Ford F-250 Super Duty Lariat 5.4L
