1992 Toyota Corolla, CKP Sensor, CMP Sensor, IC Circuit, Injector Waveform
This vehicle uses the ESA system. In first part of capture, coil primary has been shorted. Vehicle started when short from coil was removed. This test was done as an experiment.
| Component | , , , |
1992 Toyota Corolla 1.6L
| Component | , , , |
