1990 Ford Taurus, O2S Waveform
Vehicle passes CA Smog Check at 2500, but pukes at idle. Check eng lt off. Three wire sensor. Blown #5 fuse in fuseblock. Replaced and checked sensor. Looks dead as a doornail. In the negative voltage after running for 3 minutes at 2500 rpm. Waveform taken at ...
| VIN | 1FACP50U5L |
1990 Ford Taurus GL 3.0L
| VIN | 1FACP50U5L |
