Rear Balance Sprocket and Crank TDC Alignment Honda 2.2 Liter
As you look at the sprocket on the right, this is the sprocket that
turns the oil pump and the rear balance shaft. This sprocket is and
integral part of the Rear Balance Shaft Gear Case.
