1995 Ford Ranger, CKP Sensor, CMP Sensor Waveform
Posted to the Waveform Library on 3/18/2004
Cam & crank sync. If cam sensor was 180 out, #1 waste firing event will line up with rising edge of cam sync. If cam sensor is properly sync, the compression firing event will line up with the rising edge of cam sync.
1995 Ford Ranger XL 3.0L
Engine3.0 L / 6 cyl / GAS
Trans4-speed AutomaticTransmission (Electronic)
Component,
ConditionKnown Good
Component,
ConditionKnown Good
