Closed loop dyno cooling tank
Posted to the Waveform Library on 7/16/1999
500 gallon antifreeze/water dyno cooling tank, 3 phase pump, pressure gauges, pressure by-pass, filter etc. NOTE: there is a pressure gauge before and after the filter, so I can determine when the filter is getting plugged up. The filter is hard to see in this...
