Genisys Scope Clipping
Posted to the Waveform Library on 8/26/2003
This is a coil primary signal on a 94 3.0 Taurus. I lowered the time base to try and see the rotor gap in the firing line. What I see is that the scope appears to be clipping the signal at 200 volts. I saw this on other cars as well. Also the signal does not l...
